opniao motores
Mensagem por rbblue » 23 jul 2008, 23:05
Aqui vai uma lista de motores da toyota mas o ultimo [hum]
The 13B is a 3.4 L (3431 cc) inline 4 8 Valve OHV direct injection diesel engine. Bore is 102 mm and stroke is 105 mm, with a compression ratio of ?:1 (same as the 3B but with direct injection). Output is ? hp (? kW) at ? rpm with ? ft·lbf (? N·m) of torque at ? rpm.
The 13B-T is a turbocharged version of the 13B engine, with a compression ratio of 17.6:1. Output is 120 hp (89 kW) at 3400 rpm with 159 ft·lbf (284 N·m) of torque at 2200 rpm.
The 4B is a 3.6 (3661 cc) inline 4 8 valve OHV diesel engine. Bore is 102mm and stroke is 112mm.
The 14B is a 3.6 (3661 cc) inline 4 8 valve OHV direct injection diesel engine. Bore is 102mm and stroke is 112mm, with a compression ratio of 18:1. Output is 98 hp (72 kW) at 3400 rpm with 240Nm of torque at 1800 rpm.
The 14B-T is a turbocharged version of the 14B engine.
The 5B is a 4.1 L (4104 cc) inline 4 8 valve OHV diesel engine. Bore is 108 mm and stroke is 112 mm.
The 15B-FTE is a 4.1 L (4104 cc) inline 4 16 valve OHV direct injection diesel engine (same configuration as the 15B-FTE but no turbo and intercooler). Bore is 108 mm and stroke is 112 mm. Output is 115 hp (85kW) at 3200 rpm and 290 Nm of torque at 2000 rpm.
The 15B-FTE is a 4.1 L (4104 cc) inline 4 16 valve OHV direct injection turbo intercooled diesel engine. Bore is 108 mm and stroke is 112 mm, with a compression ratio of 17.8:1. Output is 153 hp (114 kW) at 3200 rpm with 282 ft·lbf (382 N·m) of torque at 1800 rpm.
The 1HD-T is a 4.2 L (4164 cc) straight-6 SOHC turbocharged diesel engine. Bore is 94 mm and stroke is 100 mm, with a compression ratio of 18.6:1. Output is 162 hp (121 kW) at 3600 rpm with 267 ft·lbf (361 N·m) of torque at 1400 rpm
The 1KZ-TE is a 3.0 L (2982 cc), 4 cylinders, SOHC, 2 valves per cylinder turbo diesel engine. Bore is 96 mm and stroke is 103 mm, with a compression ratio of 21.2:1. Maximum output is 130 hp (97 kW) @ 3600 rpm with maximum torque of 29.3 kgf·m (287 N·m) @ 2000 rpm. Redline is 4400 rpm.
The intercooler equipped version of the engine power up to maximum output of 145 hp (108 kW) [Aust. 130hp (96kW)] @ 3600 rpm and maximum torque of 35.0 kgf·m (343 N·m) @ 2000 rpm.
1KD-FTV a 3.0L (2982cc) straight-4 common rail variable nozzle turbo (variable geometry turbocharger) coupled with a 32-bit ECU and Multi Pilot Injection System, diesel engine Turbo diesel engine with an Intercooler. It has 16 valves and a DOHC (double overhead camshaft). Bore is 96 mm and stroke is 103 mm. It powers 170 hp (125 kW) at 3400 rpm, and 35.9 kgf・m (352 N·m) of torque at 1800-3400 rpm. Redline of this engine is at 4200 RPM. Compression ratio is 17.9:1.1
VD-FTV
Type: V8 DOHC 32 Valve Variable Geometry Intercooler Twin Turbo Diesel
Displacement: 4461 cc
Compression ratio: 16.8:1
Fuel System: Common Rail Direct Injection
Maximum power: 195 kW (265 PS) at 3400 rpm
Maximum torque: 650 N·m (480 ft·lbf) (43.8 kgm) at 1200 rpm
Mensagem por Eduardo » 24 jul 2008, 01:46
VD-FTV
FONIX.....brutal... :eek: :eek: :eek: :eek:
P.S. Pepo....Cummings???....CAT??.... :unibrow: :unibrow: só para ser do contra :D
Mensagem por pepo29 » 24 jul 2008, 12:49
Eduardo Escreveu:Boas
VD-FTV
em k carro mora esse motor :eek: :eek: :eek:
k loucura [clap]
Mensagem por GatoYzf » 24 jul 2008, 18:31
Eu continuo na minha 535d
Mas como dizem que um cabstar e superior :rolleyes: :confused: aqui ficam os numeros :)
ps. e com um pouco de sorte e tao facil arranjar um motor destes como de uma cabstar......
MOTOR
PRESTAÇÕES
Válvulas/cilindros 4/6
Cilindrada (cm3) 2993
Potência (cv/rpm) 272/4000
Binário (nm/rpm) 560/2000
Mensagem por diogo sousa » 24 jul 2008, 19:00
pepo29 Escreveu:
VD-FTV
k loucura [clap]
mal empregado esse motor neste chaço :grrr: [:p]
Mensagem por pepo29 » 24 jul 2008, 19:30
GatoYzf Escreveu:Eu continuo na minha 535d
MOTOR
PRESTAÇÕES
esse motor tem power pa dar e vender mas pa trial n tem futuro,nao me acredito k esse motor sabe nadar :D
Mensagem por pepo29 » 24 jul 2008, 19:32
diogo sousa Escreveu:
ja tou a imaginar os arabes a espera deste chaço :nod: [hum] :unibrow:
este carro vai sair ca com este motor? [hum]
Mensagem por Zezittu » 24 jul 2008, 19:42
pepo29 Escreveu:
Yap Pepo :thumbsup:
Depois quando quiseres fazer o test drive apita [wink] :thumbsup:
Mensagem por cristiano » 24 jul 2008, 19:46
ganda motor..... [hum] [hum] [hum] [hum]
preferia este ao 535 d....
Mensagem por diogo sousa » 24 jul 2008, 20:07
pepo29 Escreveu:
não esperes mais man [}:)] [}:)] ora toma la um videozito :thumbsup:
http://br.youtube.com/watch?v=OYyTYi7V8EE
Mensagem por Vendaval R Pereira » 24 jul 2008, 21:59
MOTOR
PRESTAÇÕES
Olha que o Toy as 1200 rpm tem 650 n.m :eek: isto é pouco mais que :unibrow: ralentim
Saudaçoes TT...
Mensagem por pepo29 » 25 jul 2008, 13:29
Zezittu Escreveu:
pepo29 Escreveu:
Yap Pepo :thumbsup:
nao digas isso duas vezes :D :unibrow:
Mensagem por Eduardo » 25 jul 2008, 13:37
Que eu saiba é nestes 3 que vem montado
Nesse outro ai de cima não sei :confused: , que modelo é isso??
Mensagem por Vendaval R Pereira » 25 jul 2008, 13:46
é o novo HDJ 200. ou melhor LAND CRUISER V8
os que meteste na foto acho que são os novos serie 70, trazem esse motor mas só com com um turbo e 200 cv
o V8 é biturbo :eek: e dá 286 cv as 3600
8,2 s dos 0 aos 100 (mais ou menos o meu trol :rolleyes: )
já agora o preço- 126 000€ :crybaby:
Saudaçoes TT...
Mensagem por GatoYzf » 25 jul 2008, 14:38
Vendaval R Pereira Escreveu:
MOTOR
PRESTAÇÕES
Concordo com isso mas tens tambem ha que ter em atenção a cilindrada de cada um e o numero de cilindros, logo tamanho e peso de cada um ;)
e o factor existencia, enquanto os motores dos 535d já aparecem usados para venda esses ainda nem novos ;)
Mensagem por a c » 25 jul 2008, 20:38
GatoYzf Escreveu:
MOTOR
PRESTAÇÕES
aplicar o motor do bmw 535d num jipe deve ser uma coisa boa para kem n tem cabelos brancos
Mensagem por TDI_sport » 25 jul 2008, 23:59
a c Escreveu:
Sem duvida... e que caixa é que se consegue la meter :rolleyes:
Mensagem por motopi22 » 29 jul 2008, 00:04
mas o que é isto gabar motores da toyota dass voces não deve conhecer os motores NISSAN um td42 135cv, tb48de 280cv, vk56ve 340cv, tb45e 230cv não chega querem mais pontencia SEMPRE NISSAN
xau ppl
Mensagem por pepo29 » 29 jul 2008, 13:01
motopi22 Escreveu:mas o que é isto gabar motores da toyota dass voces não deve conhecer os motores NISSAN um td42 135cv, tb48de 280cv, vk56ve 340cv, tb45e 230cv não chega querem mais pontencia SEMPRE NISSAN
xau ppl
essas referencias de motores pa kem nao sabe fica a perceber o mesmo :nod: [bigsmile]
abraço [wink]
Mensagem por Eduardo » 29 jul 2008, 21:47
Realmente é um pouco vago, mas tambem não há muito a explicar...estes são os VERDADEIROS motores do GR, e não esta treta (rd28t) com que foi montado na Europa e em poucos outros sitios...
Acho que é mais ou menos isto
TB42S -> 4.2, gazolina L6 (carb.)
TB42E -> 4.2, gazolina L6 (injeção)
TD42 -> 4.2D, L6
TD42T -> 4.2TD, L6
TD42Ti -> 4.2TD intercooler, L6
TB45E -> 4.5 gazolina, L6
TB48DE -> 4.8 gazolina L6(veio substituir o tb45e em 2002, e é a referençia nos 6emLinha)
VK56DE -> 5.6 gazolina, V8 (equipa a nissan Titan e não o Patrol)
Nissan tem muitos motores....fonix :eek:
http://en.wikipedia.org/wiki/List_of_Nissan_engines
Se é para competir porque não um RB30S, daqueles que sairam no patrol 260, são a carburador, mas bem mexidos são umas bombas (e têm muito por onde mexer) e aguentam que se fartam, n deve ser façil tirares mais de 800bhp as 7000RPM de nenhum dos motores diesel acima falados, e deve ser fáçil adapta-lo num GR :rolleyes:
http://youtube.com/watch?v=_ea3_X_rfcM
Ou porque não um motor do 300zx :confused:
http://youtube.com/watch?v=TbPF4ex-UyY
São apenas ideias /bitaites [wink] :thumbsup:
Editado pela última vez por Eduardo em 30 jul 2008, 09:50, num total de 2 vezes.
Mensagem por Vendaval R Pereira » 29 jul 2008, 21:55
[hum] [hum] [hum] [hum] [hum] [hum] [hum] [hum] [hum] [hum]
eu até era capas de dar 5000€ por um 4200td e respectiva caixa!
e montava no meu chasso.
o problema é que não á disso na europa!
Saudaçoes TT...
Mensagem por rbblue » 29 jul 2008, 23:45
Bem entre motores(diesel) da Nissan e da Toyota eu vou pela Toyota(1KZ-TE ou 15B-FTE)agora se for a gasolina existe outras opções, mas a Toyota tambêm os têm :unibrow:
Engine R32V type V8 head DOHC valves/cyl 4 years 89-90 cc3168 power [hp] 800
Editado pela última vez por rbblue em 29 jul 2008, 23:50, num total de 1 vez.
Mensagem por pepo29 » 29 jul 2008, 23:49
Vendaval R Pereira Escreveu:[hum] [hum] [hum] [hum] [hum] [hum] [hum] [hum] [hum] [hum]
aki bem perto na inglaterra conxegues esse motor...é ja aki ao lado :unibrow:
Mensagem por TDI_sport » 30 jul 2008, 09:56
pepo29 Escreveu:
Compras o jipe inteiro por menos de 5000eur.
Mensagem por ruidesousa » 30 jul 2008, 11:35
Utilizador a ver este Fórum: Bing [Bot] e 1 visitante
